slakker »
https://forums.nicoclub.com/slakker-u10544.html
Sun Feb 22, 2004 11:17 am
Ditto. I never removed the wheel, but it has to be removed oly one way. With the wheel al the way in the down position. Pull the trim as far out as possible, Then turn the trim counterclockwise from 3 - 9 oclock to 1 - 7. Your right hand being at 7. You will have to flex it ever so gently. this is the only wayy I have founsd to get it out. I didnt damage mine, be gentle. There is a moment where youll have to put siome strenght into it though. Good lyuck
