slipnfall »
https://forums.nicoclub.com/slipnfall-u4227.html
Thu Mar 31, 2005 11:45 am
Did it just stop working, or never worked? Before you go buying parts, you might want to check your connections... Somehow in the process of my car being jacked up/down(wasn't drivable), and rolled around, my one connector came lose at the rear of the instrument panel... It was the harness-to-harness connection, not the back of the panel. It also took out the gauge backlight(ones that light so you can see the tach/speedo markings), so that's a tell-tale sign. Also check under the car, where the speed sensor cable hooks into the engine room harness, it's only a 1/2" square connector.
Your mechanic may have tried these things first, but it doesn't hurt to check yourself.
