rhillman75 »
https://forums.nicoclub.com/rhillman75-u155149.html
Wed Jun 23, 2010 8:59 pm
Okay... here is what i have. There is continuity between the harness of the speedometer and the ECU, pin 10 on the speedometer (white/blue) and pin 26 of the ECU. However... when i test the VSS wire off the speedometer while it is plugged in the cluster and have the vehicle lifted and running and in drive...i have only 5 volts positive from my meter and it does not gain voltage while the wheels turn faster. Does that sound like the speed sensor is bad? If thats what it sounds like then that is the only part that i have not replaced because i can't get it out. Any thoughts of removing it if thats what you think?
