djtodd »
https://forums.nicoclub.com/djtodd-u5806.html
Fri Mar 14, 2003 3:12 pm
Never actually taken the sensor out, is it located on the bottom of the transmission (I wouldn't think so), or on the top half?
Logic suggests that if its on the bottom then...well yes, its all gonna leak out, but if itsnear the middle to upper half then no, it won't all leak out. No sweat though, just refill it :-)
You only want it filled to the filler plug level though. Just remove the filler plug (the one on the side) and stick your finger in, it should be about level with that hole.
I have always refilled it from the shifter, which is probably the easiest way unless you've already got the transmission down.
