Speedometer Question?
TougeChallenger
Car: 91 240SX
Hi, I have a SRswaped S13 and my speedometer recently stopped working correctly. Sometimes it will work fine and sometimes it will bounce around and the needle will stick at 85mph or pass 110. The car is a 1991 so it doesnt have the SOHC problem with the gauge cluster not working correctly with the SR swap. I was thinking it could be a speed sensor? If someone could give my some clues on how to fix it that would be great.
180fan
Car: 89 fastback
sounds like you're already on the right track.
TougeChallenger
Car: 91 240SX
Cool, Do you know where the speed sensor is located exactly on the transmission?
180fan
Car: 89 fastback
last sensor and sticks out of the transmission a decent amount and held in with a bolt iirc
leper421
Car: Current: 2011 370z
Previous: 2003 350z, 1991 240sx
180fan wrote:last sensor and sticks out of the transmission a decent amount and held in with a bolt iirc
Correct. Although it doesnt look like any of the other sensors. Looks kinda like a 2" diameter cylinder, maybe 1-1.5" high. Should be on the passenger side close the rear of the transmission.
TougeChallenger: I assume you have the stock usdm 5-speed, right?
TougeChallenger
Car: 91 240SX
No i have the JDM trans that came with the SR.
180fan
Car: 89 fastback
don't mean squat. they still come out the same factories. still the same place.
