Speedometer problem, help
achidrift
Car: Nissan 240sx 1991 (Sil80) - SR20DET
when i accelerate, doesn't matter if i go fast or slow, the speedometer stay in 80kmh, so what i have to do?? to fix this problem, or what i have to change??? and when the car turn off, the gauge drop to zero, like normal...
SkinnyKibbles
Car: 1990 240sx
check the speedo sensor, its on the transmission. Pull is it out check it, follow the wire back and see if there are any crossed or breaks.
http://www.courtesyparts.com/2....html
Part#: 25010Y
Assuming you have a S13 89-90 like me that is. this should give you an idea where it should be on your Manual transmission.
achidrift
ah ok, wooh is a little expensive to be a speedometer sensor; another thing that cause the problem??
SkinnyKibbles
Car: 1990 240sx
Hey, everything from that website is expensive. Best chance is to take a look at the car.
achidrift
ok, thanks, tomorrow i will take a look...
jetroy240
Car: S13, AE86
check your odometer(mileage), if it's working, chances are u have a bad speedometer head. If odometer is not working, I would test the speed sensor at transmission. remove it & visually check the gears if they are worn. Check the wiring connection . While it's out, check the voltage betweentwo terminals,while turning it by hand, u should get approx. 0.5 volt AC.Remember to set ur digital voltmeter to AC not DC.
vancouverbc
Car: 1991 240sx
try rock auto.com or buy it used. i think the 91 93 have the same one as you
look up speed sensor in tutorials
achidrift
another thing, i have the sr20det, it's same sensor???
WI_240sx
Car: 1990 Nissan 240sx se fastback
they have to be similar or else the speedo wouldnt read right, but i doubt they are identical.. not alot of ka and sr parts are interchangeable, but you could always go to a junkyard and try and find a KA trans, the sensor is held in by 1 bolt in the transmission.. comes out real easy, i always thought it looked like the KA distributor. ha
