PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.html
Mon Dec 06, 2021 5:15 pm
I would think the sensor should work either way, but it would definitely be best to try a different sensor, or pull the cluster and try to activate the speedo manually on a bench to test its function. Most are getting crusty and need the solder joints re-done at this point.
