speedometer not working
GatorS14
Car: 93/s13/white,96/s14/crashed...ask about parts
I have a 91 b13 automatic.the guy that sold it to me said he just got a new transmission put in,but the guy put a diferent year transmission so the spedo plugs didnt fit together.
Can someone elaborate on this?Is there some splicing i can do to make it work?Any suggestions?
thanks~
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
I believe the B13's use a mechanical pickup, and the B14's use an ifrared pickup. If he put in a transmission from a B14 then the speedo pickups will be different. I don't know what to tell ya. You may possibly be able to replace the actual pickup on the transmission with a B13 one, but I'm not really sure.
GatorS14
It would help me out alot if i could figure out which transmission he put in but, the guy has no clue....
any way to look and determine which year?
GatorS14
I havent looked at the transmission yet but my brother said he didn't see any wires w/ plugs ??????
could be from a b14 huh?
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
What engine do you have? SR20DE or GA16DE? I'll find some more info for you.
GatorS14
it has a ga16dei appreciate info.Thanks
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
I got this quote from a friend:
"The speedo was mechanical, but also for the automatic kickdown. Just likeolder cars had a rod attached to the carb to downshift, the '91,'92s hadthe same thing. In '93, there was an automatic computer."
Don't know if that helps or not.
GatorS14
thanks
Is there a way to make it work.(probaly not huh?)
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
I have no idea.
NISTECH
if you still have the old speedo pick up out of the old trans count the teeth on the gear. take the one out of your new trans and count the teeth on it if they match and they bolt up the same way you can use it .
if they do not have the same teeth on the gears but they both bolt up the same. inspect the shaft the gear is mounted on if the are the same type of shaft and the same length swap the gear from your new one to the old sensor and install your new sensor with the old gear in the new trans.
if they dont bolt up the same your pretty much stuck with out a speedo
