OutToWinPAHC »
https://forums.nicoclub.com/outtowinpahc-u66900.html
Wed Jun 13, 2012 6:22 pm
It is an AC signal the VSS is a electromagnetic motor spun backwards aka a generator. One side goes to ground, because the cluster also uses chassis ground, and the other side goes to the cluster, with that the speedo will work. But now you have the old factory wiring going from the old VSS wires to a connector in the front of the car, to a connecter on the body to a connecter under the dash to the cluster and your trying to bypass this, because you question it. So remove cluster, flip over and you will see the 4 screws that hold in and make the electrical connections to the speedo. One is battery, one is ground, one is in, one is out. With the VSS connected to chassis ground on one wire run the opposite wire directly up to the IN of the speedo, once that is done you will want to visually follow the tracing to the connectors for the cluster, locate the terminal and cover it with and insulator that way when you plug the connector in your not hooking up the wire you think is bad that is causing you to do this.
