speedometer is not working !! HELP !!
silviaz13
Car: Silvia14
i got a redtop sr20 s14 5 speedthe speedometer is not working,only RPMany ideas??what do i need to make it works?thanks alot god bless you
Hijacker
Car: '92 240sx Convertible
'94 F-150
put an S14 speed sensor in. If you already have one in there, make sure it's plugged in properly.
After that, make sure the wiring for the dash connector is done right.
silviaz13
Car: Silvia14
Hijacker wrote:put an S14 speed sensor in. If you already have one in there, make sure it's plugged in properly.
where i can find the correct sensor for my setup?and also how much labor do you think it will be?thanks again
Modified by silviaz13 at 2:54 PM 9/3/2008
exhsturbine
Car: 1997 240
speed sensor should have come off your ka. its located on the transmission towards the rear on the passenger side. its not too hard to get to. if it helps you can unbolt the crossmember so that the transmission will lean back and you can get to it. follow the wiring up the transmission and makes sure the connector is secure.
