Speedometer help - rb25 + 6 cyl tach + 300zx diff = WAY OFF
supermario680
Car: 90 300zx NA 2+2 stage IV
So my s13 has a rb25 with a 6 cylinder tach and a 300zx rear diff, with the new tach the RPMs are correct but the speedo is WAY WAY off... Anything I can do to fix this?
BoredEE
s14-speedometer-correction-with-z32-transmission-t472168.html
I've lost the link to a thread that tells which solder joint to connect to affect which % on the speedometer.
But I'm sure a few minutes of searching will turn it up.
Oh I see its for a s13, maybe the s13 has the same correction solder joints.
Otherwise you can always buy a dakota digital.
There are different speedometer pinions you can try on the speed sensor but I have no idea which one you'll need.
Maybe a 300zx TT pinion will work.
FYI:
http://pic20.picturetrail.com/VOL1569/9 ... 761118.jpg
supermario680
Sweet thanks I'll check it out
nismoplsr
