Speedometer help please, s13 rb20
AxiOn419
Car: 1991 240sx SE Super-Hicas w/ RB20DET
After installing the rb20 in my s13 hicas car, the speedometer is not working. This rb20 came out of my previous s13 without hicas if that matters and the speedometer worked just fine, so I know the wiring for the cluster is right. The tac is working properly as well. Could I simply be overlooking a plug? Where is the exact plug location for the speedometer?
Any info will help, thanks
My buddies speedometer is not working in his 25 so maybe we can kill two birds with one stone here
Oh, and yes, I searched
AxiOn419
Anyone able to help me out?
craz4240
Car: 1995 240sx w/rb20det
Not really a hard thing man if you wired it in properly...then check the plugs.
AxiOn419
craz4240 wrote:Not really a hard thing man if you wired it in properly...then check the plugs.
Thats the problem, I am not the one that wired it. 3 years ago a local shop did the wiring in my old s13. That car was wrecked, so we pulled everything out and put it in my new s13, same wiring harness and all. The speedometer worked previously, now it isnt. Where is the speed sensor plug located? Maybe it came unplugged, just dont know where to look.
craz4240
Speedo sensor plug is on the transmission man.
jrd450r
Car: 1990 RB25DET S13
Correct me if im wrong but I belive the RB20 has the same speed sensor as the KA so it should wire up and work fine. On the other hand with the rb25, its not that easy, Ive still yet to get my rb25 speedo working, I havent tried fixing it yet but simply just wiring to the 25 sensor, it does not work properly.
DJButton
Car: 2010 Nissan 240sx
I have an SR plug on my car, but I KA one would work fine as well.
AxiOn419
Alright, I will have a look when i get home, thanks for the help everyone.
craz4240
jrd450r wrote:Correct me if im wrong but I belive the RB20 has the same speed sensor as the KA so it should wire up and work fine. On the other hand with the rb25, its not that easy, Ive still yet to get my rb25 speedo working, I havent tried fixing it yet but simply just wiring to the 25 sensor, it does not work properly.
rb20 has a cable driven speed sensor...I know the s14's have electric pretty sure s13's do as well,hence what you have to do is replace the rb speed sensor with the 240'sx speed sensor.
