speedometer dont work
NaH
Car: 1995 Nissan 240sx SE
The speedometer doesnt work neither does the Tachometer, the car has a SOHC Cluster but its a DOHC engine, just didnt have a DOHC cluster when they did the swap. should the speedometer still work? is that the speed sensor? or does the cluster stop it from working since its sohc cluster?
NaH
needmorenissan
Car: 1993 Nissan 240sx and to much to handle
check ur vss on ur transmisson and see if its still there and theres 2 wires coming out and not 1
project_240le
Car: 1991 nissan 240sx le
as for the tach, the SOHC tach will not work with a DOHC engine; they run on different signals. Your best bet is to get the whole gauge cluster from a DOHC car and swap them.
