96stillen_max »
https://forums.nicoclub.com/96stillen-max-u15316.html
Sun Nov 21, 2004 9:46 pm
about 6 months ago, my transmission blew out. when i had it taken out, the harness for the speed sensor, more specifically the wires were ripped apart. when my new transmission was put in, the mechanic reconnected the wires with wire butts and ever since there, its worked perfectly.
3 weeks ago i had a new clutch put in and again, when the transmission was taken out, the wire job that the previous mechanic did was ripped appart. i ended up ordering a new speed sensor and harness. after everything was hooked up, the spedometer does not work. the fuse is fine, all the other guages work except for the spedometer. the gauge cluster works fine, its sending and recieveing the proper signals.
basically what happened is that everything was working fine, then i got a new clutch put in and once everything was put back together, the spedo doesnt work...which to me and my mechanic makes no sense. what could be wrong?
