Speedometer doesn't work and it's not the sensor.
Jayzeon
Car: Nissan 240sx se 1990
I checked my speedometer with a multimeter and it read 0.5 when i spun it fast. and when it was placed back into the transmission it read about .7 in first gear with the car on blocks but the speedometer still didn't move.
What could be the problem?
180fan
Car: 89 fastback
possibly your speedo or the wiring in between if you say the sensor's fine.
navysnail
do you have the HUD speedo
s13sr20chris
speedo head is common failure item. go junkyard.
Jayzeon
no it is not electrical, but now it goes up slower than I'm really going, and then when I know I'm doing about 50 it reads about 75. Would the Ecu have anything to do with it?
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
no, the speedo feeds the signal to the ecu, not the other way around.
ILikeMy240sx
Car: SR Power
1. Check the harness of the spdometer
Check continuity of terminal 22 and body ground. If good move on. If not Repair harness or connector
Check voltage between terminal 21 and body ground. If you read battery voltage move on. If not repair harness or connector
If those two were good then it's your speedometer. Since youve already checked the voltage between 28 and 35(0.5V)... and the circuit is good so it's your speedometer
This is from the FSM. Also, refer to my thread as well.http://www.nicoclub.com/zerothread?id=87704
Jayzeon
Hey I will try that, but I am not sure what you mean about 22 and 21 terminal. I have taken out the speedometer cluster and check the connections visualy, but I will check the plugins for voltage, meaning the plugin that goes to the side where the speedometer is connected.
thanks for you help so far!!!!
ILikeMy240sx
Car: SR Power
i meant the terminals on the harness that connects to the speedo
Jayzeon
Yeah in the back of the cluster
Jayzeon
hey I just checked my ecu and the codes it gave me was 14,33, and 41 what is 41 code would any of these problems cause my car to shut down at 3500 rpm or above. when I say shut down I mean like if my govner kicked in. what 's up with that eh.
any info is helpful!
