Speedometer Cut
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
I know a few people have done this and I'm wondering if anyone can tell me how to do it.
Ive talked to a few people who i believe cut a wire in-line fromt eh cluster to the transmission and through a switch on it. Making the speedo/odo/trip not work when the switch is in the "x" position and and it works when in the "y" position.
Anyone know how to/what wire/where i can find info on it?
drifter_for_life06
Car: Daily: '16 WRX
Exocet
bump
anyone?
ichimabax
There is a wire that goes from your speedo to the ECU. I believe its green and yellow. You cut that and your ECU will never see the speed but your speedometer will still work tho.
If you want you can throw a switch inline with that wire as well.
I dont know if SR20 has a rev limiter in 4th and 5th
wildacexxx
Car: 2002 Q45 nav sport
just get a speed cut limiter. they're not that expensive and u can retain everything.
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
Slightly off the topic, but I was wondering... Someone told me that if the ECU doesn't see a speed signal for 10 seconds at WOT, the engine will shut down.Is that true?
drifter_for_life06
Car: Daily: '16 WRX
Exocet
sorry if i misled everyone
im not looking for the speed/rev limiter
i want to *cough*make my odometer not work*cough* which i believe can only be done by disabling the speedometer
Please correct me if im wrong
