speedometer correction when DOWNsizing tires
internetautomart
Car: more than you!
currently 94 u13 (electrical gremlin), 97 u13 (incoming)
I have a 94 pathy that is stock on 31s. I want to go down to the regular stock size of 235/75/15.I do know that the VSS is different, is that the only difference though?Can I just swap out the VSS and my speedometer will read right?thanks in advanceBrian
timmack
Car: 2002 Nissan Pathfinder SE
should be able to, i dont see why not.
internetautomart
Car: more than you!
timmack wrote:should be able to, i dont see why not.
me either, but that is why I asked.
Though it looks like I scored a set of the correct size tires for cheap enough.
time for a different question after I search
bmlawless
Car: 1999 Infinity QX4
internetautomart wrote:I have a 94 pathy that is stock on 31s. I want to go down to the regular stock size of 235/75/15.
I am confused. Is the stock tire size 31" or 237/75? If someone before you put 31's on, they probably never made the change so your current reading is off and will be corrected when you put the correct size tires on.
I am only asking because I have purchased three vehicles with bigger tires and in all three cases, no one re-programmed the ECM or replaced the speedo gear.
internetautomart
Car: more than you!
bmlawless wrote:I am confused. Is the stock tire size 31" or 237/75? If someone before you put 31's on, they probably never made the change so your current reading is off and will be corrected when you put the correct size tires on.
The factory offered both tire sizes.Mine came from the factory on 31s
I was thinking of putting the 235s on. it's a moot point for me now as I am picking up some 31s in a little while for "cheap".
