joes240 wrote:He discovered in the fuel tank "a basket like thing where the fuel pump sits in" which was not letting fuel pass through it properly, to fix the problem, he drilled a small hole into the basket-like apparatus and fuel pumped fine, allowing the car to run fine. Another friend of mine was looking at the car for me and said that is not good, that I should get that part (whatever it's called) replaced, otherwise any dirt in the fuel tank could wind up in the injectors. Can anyone give me a second opinion on this, or what the part is called?
That sounds to me like it's the diaphragm. Yes, that needs to be replaced...not a whole drilled in it. And without that there, and dirt that can fit through the fuel line will be likely sucked up and on a path towards the injectors (bad thing).
Quote »Also, the speedometer in the car stopped working one day after he went out and started the car up after it hadn't been started in a few weeks. Is that year Sentra controlled by a speedometer cable or a speed sensor/head?[/quote]There is a speedometer cable on the transmission.
Quote »We also discovered that the front flashers/blinkers sometimes flash alot faster than they're supposed to, and sometimes flash fine... any ideas here?
Thanks in advance for any input folks! [/quote]
Check your bulbs. If all the bulbs are good, check to see you have the right kind of bulbs (should be single element bulbs for the turn signals). If all is still good, you have a short somewhere.
