youngmanvr4 »
https://forums.nicoclub.com/youngmanvr4-u32791.html
Fri Dec 22, 2006 3:44 pm
First off my speedometer works on and off...mostly off though lol. I have done some searching and I know about replacing the speed sensor, checking wires/connections, fuses (though I know its not fuses becuase it works on and off). I'm in Texas right now and the car is in Kansas but I will be going back to pick it up at the first of the year. Would like to have a speedo for the 1,000 mile trip.
Now for the story of when it started.My transmission went out so I bought a used transmission from a local guy. When I was swapping trannys I took the speed sensor off of my old transmission and put it on the transmission that was going in. Before the swap the speedo had worked fine. Never had a problem. Finished the transmission swap and now the speedo doesn't work. Like I said before the swap it worked, finished the swap and now it works on and off. I checked and cleaned the wires and connections under the car, didn't fix it.
So I've came to one of a couple things.
1) During the swap the sensor got damaged and is only working on and off.
2) The speedometer gear inside of the transmission is worn down and only catchs some of the time.
3) Not enough oil in the transmission and the gear only moves sometimes. Which I filled the transmission up the the fill plug on flat, level ground, so I doubt its that but just a though.
4) The speedometer itself went bad out of no where. Note that in lights up, just doesn't move most of the time.
I would say its the sensor but the thing that makes me question it is that it worked fine before the transmission swap, and now after it doesn't. Thats what makes me think it could be the speedo gear inside the transmission itself. But I hope its the sensor becuase I dont want to have to do anyother transmission swap.
When I doesn't work it just stays at 0. Sometimes it jumps from 0 to XX (whatever speed I'm going) and just bounces like a mad man. And sometimes, rarely, it will actually work right....for a little bit at least. Over all I have the gear x rpm =speed figured out but I need to have the speedo going. I dont like relying on rpm to know my speed plus I dont know if its 100% correct, but it works for now.
So if someone could help me out and give input that about be great. Thanks.
