I'm not sure what power steering and the speedo have in common but it happens a lot with the older Q45's.yodawill2000 wrote:Interesting. So there is a connection. Thanks goody90q45 !!!
Super HICAS (High Capacity Actively Controlled Steering) system found on the Q45. The system used a precise, computer-controlled hydraulic rear steering unit on the rear wheels. At high speeds, the rear wheels were steered up to one degree in the same direction as the fronts. At low speeds, the system would momentarily turn the wheels opposite the fronts (to help point the J30t into the turn) before turning them in-phase. The sporty J30t also received revised spring calibrations, new alloy wheels, and a rear spoiler.
