Jdmpwr »
https://forums.nicoclub.com/jdmpwr-u203653.html
Wed May 02, 2012 7:51 am
This is 2002 Infiniti I35. There is no change in the car whatsoever, it runs and drives normally. And it only occurs at certain times:
When I leave for work at 4:15am it works fine, like nothing is wrong. My commute is 45 mins, after about 30 mins or so, the lights come on and the speedo stops working. After work at 2:30, I get in the car and it works normally again, then after only about 10 mins, it stops working for the entire way home.
I am assuming it is something to do with the heat. I called an Infiniti service dept. at the dealership and he said it could be the cluster. But I took it to Autozone and hooked it up to the scanner, and got codes for the TCS module, and the Speed Sensor.
What do you think?
Thanks for any information that anyone can provide.
Jdmpwr on Wed May 02, 2012 10:38 am, edited 1 time in total.
