speedo sensor
DropTopRB
Car: 1993 240sx convertable, RHD, chargespeed s15 front end and wide body full kit, powerd by rb25det
So i purchased a speedo sensor from a 91-94 300zxTT, and it dosent fit, its way too long, but i have herd of people using sensors from the 300zx's. Should i have bought for an n\a 300zx speed sensor?? Thanks
DropTopRB
sorry, forgot, its a s1 rb25det..
Bwana
Car: Denali
IIRC the n/a would be the one you want.
streeteg
Where does the speedo sensor go? I am trying to hook up an aftermarket speedo on my RB25det swap as well..
s13point5
Car: 89 240sx
the vehicle speed sensor is on the transmission
streeteg
so I get the N/A 300 wire---- one end goes to the tach the other to the speed sensor on the transmission?
I know that sounds stupid but this is the first time dealin with such a project....
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
The 300zx speed sensor N/A or TT shouldnt be any different, if you have it, and stick it in with the red gear on the end, it should work. Also.... Where is the sensor input? If its on the back of the transmission towards the shifter you dont have an RB25DET transmission, if the sensor input is on the middle of the transmission, then it is a RB25DET transmission.
DropTopRB
The sensor imput is on the end of the transmission. The transmission came on the engine, it just didnt have any sensors in it. Do you think that the transmission will work, ive had it off to put the clutch and flywheel on, and i replaced the throw out bearing, and everything went smooth. What are the possiablities of trannys that it could be, the sensor looks like it needs to be alot shorter??? I need some serious help, i got fu**ed on this engine. Wrong ecu, wrong transmission, wrong wiring harness, and the shop wont do anything for me....Im really starting to get discouraged. Maybe i should have just stuck with the sr. Thanks everyone...
rotorimp
Car: 02 Xterra, 60 IH Metro
AC Delco part number is "SC78"---$40 brand new, which is the same as Nissan "25911-40P10" (From a Z32 TT). All you have to do is put your old gear on it.
DropTopRB
So from compareing pictures i have come to the conclusion that they gave me a rb20 transmission, which really sucks. Does anyone know if this transmission is longer then the rb25 transmission, im afraid that my driveshaft wont fit. Also, i need a speed sensor for it, i have read that the ka24 speed sensor will fit, does anyone have one for sale, i cant really buy aftermarket because they dont come with the gear, and i need it. Thanks!
rotorimp
WOW that does suck----Did you PAY for a 25 trans???
nissanman04
Car: '90 240SX, '95 Subaru Legacy
rotorimp wrote:WOW that does suck----Did you PAY for a 25 trans???
WERD
I'd def go get it exchanged if possible...where'd you get it from
DropTopRB
I got the swap from a place in montreal called osaka, they had the best price, so thats what i went with, wish i didnt now. I wrote them an email, but they havent replyed yet so i dunno whats gonna happen with that. Does anyone know if my mckinney driveshaft will still work alright???? Also, i know with all the engine swaps people are doing someone has got to have a ka speed sensor, I NEED one with the gear on in. THANKS!
240SX GT-S
Car: 1995 240SX SE
You got yours from Osaka too? They don't have very good customer service over the phone I found out... I personally went there to pick mine up. And I've only called them once after I bought my set, and I haven't had any problems with it.
Press on my friend, I know it gets rough, but keep going!
S12_hybrid
Car: 1987 Nissan 200sx
I ordered my friend an SR20det from osaka (longblock to replace his blown SR).. They sent us a motor with bad valve seals and a seized alternator.. Then I called them and they gave me some roundabout **** on the alternator - and sent us one from a B18 integra motor?!?
They are garbage, and if you want I will go in for you on my way through montreal and smack them in the face.
-Dan
PS- Best of luck man, you're working against all odds here.
onepuff
I've got an s13 ka speed sensor. $25 if u end up using the rb20 trans.
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
Im a little new to the RB's. I about to get a already swapped 93 Coupe with RB25DET S1 engine and Trans. Speedo doesnt work because of the speedo sensor is RB. Which speedo sensor should i get? Im hearing mixed answers on what i should use.
