djtodd »
https://forums.nicoclub.com/djtodd-u5806.html
Sun Mar 30, 2003 11:51 am
No, no indicator, but if you're gonna put some in, go ahead and change it all while you're at it.
The best way to do it is drain it all, via the drain plug on the bottom, then after you're done with the speedo change, undo the fill plug on the side of the transmission, and put a pan/cup under it.
Start filling through the shifter and when it begins to leak out the fill plug, it's filled to the appropriate level.
Good luck and enjoy.
