My analog speedo doesn't work. I have put 3, yes 3 different clusters in it and still the same result. So I don't think there is a problem in the cluster. HOWEVER i know it's not the speed sensor, it's putting out voltage and i DO hit the speedlimiter, I've hit it several times in a row just to make sure. I have continuity from the sensor to the dash so i was thinking it could be the ground. But the problem is, i don't know which wire is the speedo ground. Does anyone know what wire colors are te ground(s) for the gauge cluster? I'm going to triple check all my wiring in a few days and i just want to check the grounds too.
Any help will be greatly appreciated! Thanks!
