Spoolpigeon »
https://forums.nicoclub.com/spoolpigeon-u9975.html
Tue Dec 21, 2004 5:16 am
My analog speedo doesn't work. I have put 3, yes 3 different clusters in it and still the same result. HOWEVER i know it's not the speed sensor, it's putting out voltage and i DO hit the speedlimiter, I've hit it several times in a row just to make sure. I have continuity from the sensor to the dash so i was thinking it could be the ground. But the problem is, i don't know which wire is the speedo ground.
Any help will be greatly appreciated! Thanks!
