Steady_One_S13 »
https://forums.nicoclub.com/steady-one-s13-u106202.html
Wed Apr 01, 2009 7:08 pm
Hey, Welcome to Nico!
First off, the shops here in El Paso don't know anything about the Sr20. I'm guessing the brown plug (located above glove box and ECU) may be wired wrong. Check your start signal / ignition wire (orange). Make sure it's soldered Ka orange to Sr orange. Check Tach signal wiring, Ka yellow/red to Sr yellow/red. I have a 1991 s13. So the wiring should be the same as your 1990.What type of instrument cluster do you have? Digital or analog? Digital ones often go bad, such as mine. The vss can be checked using a FSM.If you need help, do not hesitate to contact me. I live in central, close to Austin High.G/L
Btw, post pics of your ride and introduce yourself to others on this forum.
