speedo problems
projectsx
Car: 1989 240sx coupe
ok guys ive done a search and could not find anything on this. did the single cam to dual cam swap and everything is working and running great except i dont know where the speedo wires plug into do i have to splice something in order for it to work?
180fan
Car: 89 fastback
no, but you might need to change over the speed sensor. The transmission harness is the lower harness and should plug up without a problem to the car.
projectsx
180fan wrote:no, but you might need to change over the speed sensor. The transmission harness is the lower harness and should plug up without a problem to the car.
i cant find where to plug it???
nuts510
Car: sr20det 95 240sx, rb20det 93 240sx convertible, 78 280z turbo, 71 ca18det datsun 510, 72 scout,88 CR
does a speed sensor on your transmission have wires that are 3 ft. long or doesn't have a plug on top of the sensor. If they are the 3 ft. long ones you have the right sender to plug is located up near the starter on top of the wiring harness that goes to your reverse lights. If it doesn't have the 3 ft.-long lead it has a wrong sensor you need a different sensor. If you happen to ended up with one of the ones that plugs and right at the sensor it's from a later model car(I would like to buy it if it is)I have several of the ones with the long wires if you should, needing one. I hope this helps
projectsx
cool, i dont remember i'll check tommorrow and get back and post after i check
