Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Wed Nov 27, 2013 5:12 am
That's really strange. The odometer gets its signal from the speedometer, which gets it from the VSS. I dunno if the signal gets split inside the speedo so the odometer and the speedo see identical signals that are independent of each other (ie, the speedo can read incorrectly and the odo sees the proper signal), because I thought with the internal adjustment of the speedo, that the odo would be dependent.
Either or, if your odo's reading right, try swapping in a known good speedometer and seeing if that solves the issue.
