Rmay »
https://forums.nicoclub.com/rmay-u254.html
Wed Oct 02, 2002 10:20 am
My speedometer has starting acting strangly - it will all of sudden just drop to zero and stay there. Then it will start crawling up again, registering around 20 when I'm going 60. It will then work normally for awhile, and then stop functioning. Once, a week or so ago, the needle just started jumping all over the dial.
When the speedo dropes to zero, often the power steering drops out at the same time. It will return a few moments later.
I understand that the problem is probably a bad VSS. I know that in the Q this is located on the trannie; I've also been told there is one at the speedo head. Is this so, and is one or the other (which one?) the likely culprit and in need of replacement.
I also had another weird thing happen, and I don't know if they are correlated. The other day the trannie stuck in 3rd gear for about 15 miles. Next time I drove the car - a couple of hours later - the trannie was shifting properly again, and has been since.
