Speedo Help sr20 89 sohc hud to 92 dohc analog - because of ticket
skaterfromvt
Car: 1989 240sx sr20 blacktop Built not bought 87 v8 rx7 fc3(50) 95 s14, 00 dodge ram 1500
okay so i swapped the dohc cluster in place of the 89 sohc digi cluster...
Now the tach works (which is great)
but speedo does not
is there a simple way to run speed signal to the speedo...because the speed goes to 40mph and stays there...i think some how its confused with the fuel level because i pushed the fuel level down to half tank and it stayed there until the fuel level climbed back up again....
i understand that the signal wire for the speedo is the pin 32 the yellow and green wire...can i just run a wire straight from there to one of the pins in the dash sub harness? or is there other wires i have to run also...like a ground and the yellow and green wire?
or is there a way to test the speedo in the trans to see if that is the problem?
how much is a new speedo
i swapped a ca18det gears into the trans so would i need a ca18 speedo?
got a fix it ticket by feb 1st because of my speedo!!
Modified by skaterfromvt at 3:24 PM 1/14/2009
boro drift
Car: '87 Supra, '92 240 with SR20 and '98 12 valve Cummins
Swap the dohc tach into the digital cluster.
SpeedRacer1
Car: 1990 240SX, G35
If I recall the yellow/green wire is not the signal wire from the speed sensor, but a wire that goes from the cluster to the ECU. The speed sensor wires are highlighted light blue in this wiring diagram meant for the non-HUD cluster.
