speedo and tach problem
gibz4
i just noticed that my speedo and tach do not do their rotate test when i start my car now. Is this a typical problem and is there a simple solution for this? Or should i take it to the dealer and have them check. The car only has 38k on it now and its an 06.
fiveliterbeater
Car: 2006 Mitsubishi Lancer Evolution IX
2000 Nissan Maxima SE
2005 Nissan Altima SE 3.5
sounds like you turned off the "excitement" feature. my car is in the shop so i cant really help but if you go to the dealer, they will turn it on for you.
mjlyn
Car: 2006 M35 Black
gibz4 wrote:i just noticed that my speedo and tach do not do their rotate test when i start my car now. Is this a typical problem and is there a simple solution for this? Or should i take it to the dealer and have them check. The car only has 38k on it now and its an 06.
You can control that yourself. The button on the dash that controls the illumination of the rings around the gauges controls it. Just lower left of the tach.
To turn the ring illumination and needlesweep on and off, push the control knoband hold it for 1 second.
M35 Sport
Car: Infiniti M35 Sport
Oooooooh...I learned something. Good to know.
gibz4
Thanks,
Tried it and it worked. Guess i turned it off before and didn't notice it..
Thanks
mjlyn
Car: 2006 M35 Black
Glad to help
