Dlyle »
https://forums.nicoclub.com/dlyle-u229460.html
Sat Dec 28, 2013 7:53 pm
Hi, new to this group.I couldn't find a similar problem in search.
I have an '02 path w/3.5L V6, auto trans w/4WD, 170K miles. Bought used in good condition primarily to be a 2nd vehicle for backup. It doesn't get driven much. The problem I'm having involves the instrument cluster. Recently we were out looking at Christmas lights and everything was working fine. A week later I used it to run errands and I noticed the speedometer was not working. Also at the same time the ABS fault light came on, the 4WD wheel indicator went out & the 4WD fault light came on. The odometer shows vehicle mileage up to that point, however no new miles are registering. This happened once before. It was summer time and I was looking for a store that wasn't easy to find. After a couple of U-turns, I decided to stop at a gas station and ask. Up to that point everything was working fine. When I got back in & restarted the engine I noticed as I pulled out onto the roadway that the speedo was not working. I drove the 1/2 mile to the store & parked. I figured I would check fuses when I came out of the store but I forgot. When I took off, I noticed everything was working again & had no more problems til now. Don't know if there's any relation but a while ago the engine had a misfire. It went away on its own just as I was dropping it off at the garage for service. Needless to say the garage couldn't find anything wrong, so we had new plugs put in. The misfire has since come pack & the engine light is on. I took it by the garage & they said the spark plug coil on cyl 4 is bad. We haven't been able to get it repaired just yet.
The only other problem we have had is that recently we had an ice storm making the roads slick. My brother-in-law used it to get to work and used the 4WD. When I went to use vehicle later it was in 4LO with the switch in "auto". I tried to drive it on dry roads thinking it would switch on it's own. When it didn't and I couldn't switch it manually I pulled over & read the manual. I followed the instructions in the manual & everything seemed fine after that.
Sorry this is so long but I figure the more info I give, the better someone might be able to help.
Any ideas???
