speed specific vibration
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
1blackg
Car: 2004 g35x
2004 g35x with 125k miles on it. i have a slight vibration between 40 and 55 mph. i have been told many things but want to see what g owners think and know. when i get above 60 mph it smooths out. slight vibration when braking (usually at lower speeds) i know a little about cars but this one does not make sense.
telcoman
When was the last time you had all four wheels balanced?
A damaged rim from hitting a pot hole can also be the cause.
Inspect your tires and rims carefully.
Also lower control arms
With that much mileage perhaps a complete inspection at the dealer might be necessary
Good luck
Telcoman
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
