otterball21 »
https://forums.nicoclub.com/otterball21-u35559.html
Thu Mar 08, 2007 9:45 pm
Ok, Good grief, I do not understand what one is the speed sensor.Let me explain my problem. I just did a Manual swap from Auto Swap.Everything works, except my Speedometer.
So far I have hooked up the Reverse sensor, which is the sensor closest to the bell housing.
I don't have the Middle sensor and the sensor closest to the driveshaft on the transmission hooked up.
There is a Sensor on top of the transmission I have hooked up to the original Automatic transmission harness. It plugged right up, because the auto transmission had the same sensor. I literally just took it off the auto transmission and switched it over.
Ok, The middle sensor all my research have told me, inhibitor switch, or Over Drive sensor, or 5th gear sensor. I haven't seen anyone hook it up.
Then people are like the last sensor you have to hook up, I looked in Chilton and it said that it was a neutral Switch.... ....
So which one sends a signal to the speedometer?
and what wire is it next to the fuse box that I have to hook up the speed sensor wire?Any help would be great!!!!
