Speed sensor
1996QShip
Car: 1996 q45 pearl white with 66k
Can anyone post a picture of the speed sensor I need for a 96 G50. I need the one which is near the transmission. Also if someone has a functional one laying around shoot me an email. Thanks!
masshead87
Car: 1996 Infiniti Q45
Are you talking about the power steering speed sensor? Because I've been looking for months for one of those. So annoying to replace a pump AND rack and only have power steering at highway speeds.
1996QShip
No. When the speed sensor goes bad. Your power steering, and speedo stop working. It's located near the back of your transmission. Atleast thats what I've been reading
mcrews
Car: 2002 Q45 Sport
on the 02 Q45 that sensor is inside the trans at the rear 4 hours labor to replace
masshead87
After months of reduced power steering, I finally caught my speedo not working for the first time a couple of weeks ago. Made sure to see it happen again a couple more times before I finally figured out that the VSS is the problem in mine too. Weird part about it is that in many other posts, people with a faulty VSS report that their odo stopped and stayed dead for the rest of the drive, whereas in mine it cuts out for up to 30 seconds at a time and comes back on. I'm just going to replace the part with a Beck Arnley BA0905025, sells for 150 - 240USD depending on where you get it.
1996QShip
My symptoms still persist despite changing my VSS. My tach needle also bounces under heavy acceleration. NICO gurus think it may be me speedo cluster. I hope this is helpful.
masshead87
TY for the info, tach appears to be smooth in mine. I may just bite the bullet and do the voltmeter test in the FSM to make sure VSS is my problem.
