Speed sensor
DropTopRB
Car: 1993 240sx convertable, RHD, chargespeed s15 front end and wide body full kit, powerd by rb25det
K, alot of confusion here, i have rb25 with what i believe is rb 20 transmission. I bought a ka24 speed sensor for the rb20 transmission, and it dosnt fit, its too big around to fit into the transmission. Thinking i may have automatic sensor. MY QUESTION IS : when you compare ka24 auto and manual speed sensors together, whats the difference???????? Thanks for the help!
AZ89two4Tsx
Would a KA speed sensor fit into an RB transmission?
DropTopRB
s13 Ka Manual trans speed sensor should fit rb20 transmission, same bellhousing as sr20 and ka.
WDRacing
These guys should be able to help you out, since KAT guys don't usually have RB transmissions
Neejay
DropTopRB wrote:s13 Ka Manual trans speed sensor should fit rb20 transmission, same bellhousing as sr20 and ka.
bingo.
The KA auto speed sensor is longer than the manual
