Red93coupe wrote:Well I have a coupe with HUD so I can switch it back and forth between KMH and MPH and it doesnt work still any suggestions on how to fix??
First make sure that the speed sensor itself is in good working condition. There is a section on how to do this in the FSM. The sensor off a KA trans should work fine.
Second check your wiring from the sensor to the gauge cluster. Make sure there are'nt any shorts or opens in the wires.
Finally go over your connectors and check for corrosion and excessive resistance.
