speed sensor
chuy38
Car: 1996 Q45
I need help getting a speed sensor or a cluster for my 96Q45t can anyone help me??
Amesdude25
Car: 1990 Q45 1994 Q45a 2004 M45 1987 300ZX
I actually have one from a 94 but not sure if it would work with your 96... Be sure to check your cluster first as this was my problem... The damn thing would jump all over the place. First thing to do is check the voltage coming out of the speed sensor. You can disconnect from wire harnest and run to wires to the ohm tester. Either with both drive wheels off the ground or while driving. Voltage range is in the FSM as I'm at work right now. If it's within spec than it's the speedometer in the dash. You don't need a whole cluster just the speedo. I would test the speed sensor as it's eaiser to get to the transmission than taking the dash apart. Or if you do take the dash out you can test both then... your call. Of course I found this info out AFTER I bought the speed sensor. :-) Is your speed sensitive stearing acting up as well? Speedo controls this too...
Regards,
Danniel
chuy38
Car: 1996 Q45
yea! my power steering comes and goes with the speeometer. Four days ago I lost my blinking lights from dash. checked all fuses all is good .Could this also be a cluster issue.
Amesdude25
Sorry for the delay. Maybe contections are bad or something. What year do you have? I think there is a 92 in the junk yard. That's how I fixed mine
