speed sensor replaced check engine light still on
revref55
Car: 1997 200sx se-r
The check engine light came (97 200sx se-r 100k) on a few weeks ago and it checked out to be the speed sensor that needed to be changed. Then the light came back on a week after the sensor was changed. I had it checked out to see if something was loose and my mechanic friend reset the light. Well, it came back on early this week. Any suggestions? Speedometer works fine. It also just dies once and a while. Seems to be when it is cold. Could they be tied together? Thanks!!
Modified by revref55 at 9:50 PM 9/15/2006
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Was the speedsensor the only code the ecu was throwing?
nametakennow
Car: '06 MINI Cooper S
Check this code, I think it's not going to be the same. Dying while cold would have nothing to do with the speed sensor.
AWDB12wagon
Car: 1989 Nissan Sentra 4WD
Could be the speed sensor on the flywheel? dunno if its the same as the Se-R's that have the speed sensor built into the flywheel too.
hudy
Car: 1991 240SX SE Hatch
sounds like a crank sensor.
