Dave
Thanks. That's the one. I finally got it off today. It was plugged into the transfer case horizonatally on the passenger side. Pretty tight area and had to remove some brackets and lower the trans to get better access. Ended up soaking the mating surface with Kroil after the bolt was removed and tapping on the flange ear with a screwdriver and hammer to rotate the vss and break the bond. No room to use plier to twist it. Then locked a vise grip on it horizontally and used a bar to pry the vise grip using the transger case for leverage. After a few tries it finally popped out.ARKQX33V6 wrote:Found it page EC 252, has a gear inside the trans-axle, looks like an "O" ring all around. There must be a locking device that undoes then you pull straight out but you have to get over that "O" ring. The gear should let go.
This is a small gen set for reference, if you break it up it will be toast. Describe how it's positioned can you put a large flat driver into the groove and pry it out, is there enough room to work?
