pahrding »
https://forums.nicoclub.com/pahrding-u52642.html
Tue Aug 21, 2007 10:54 am
I have a 91 Q45 with 125,000 miles. The speedometer has recently, and intermittently started cutting out and seems to stay that way until the carhas been parked usually overnight. The other issues accompanying this problem are that the power steering needs a lot of muscle at low speeds, and if the problem has not corrected itself since last parked, there is an error message of "transmission malfunction". The transmission seems to function o.k. regardless.
Would a cluster failure cause lack of power steering, or would it more likely be caused by the speed sensor.
I have trouble identifying the actual speed sensor unit on the transmission . I can see a small 1" round plastic can sticking out of the transmission case on the rear pass side. Approximately how long should the terminal cable be that comes off it? Does it go all the way to the speedo cluster or plug in to another cable that goes there?
