speed sensor cut!
bmarley5780
I am pretty sure the it is my speed sensor that is cut....:( Can I rewire myself , or need a new one....where do the wires run to?
Thanks
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
WHAT DO YOU HAVE? RB20 USES A CABLE DRIVEN SPEEDOMETER IF YOU CUT WIRE 53 (IF I REMEBER RIGHT) YOU CUT THE ECU LIMITER SENSOR WIRE.
bmarley5780
yes it is a rb20hav no idea what is cut ( it waslike that)but what do i do.....?
PROJECTRB240SX
IF IT WAS LIKE THAT THEN THE PREVIOUS OWNER PROBABLY CUT THE SPEED LIMITER.
bmarley5780
so, wityh that cut i have no speed limiter. doesnt the speed sensor tell mne how fast i am going too?!
PROJECTRB240SX
NO BECAUSE THE RB20 IS CABLE DRIVEN. THE CABLE COMING OUT OF THE SIDE OF THE TRANSMISSION GOES INTO THE BACK OF THE GAUGE CLUSTER, THIS TELLS YOU YOUR SPEED. IF YOU HAVE A DIGITAL CLUSTER THEN YOU MAY HAVE PROBLEMS.
SHIFT_Lock
Car: kouki s14
use the s13 speed sensor it DOES just plug in.
vududoc
Car: drag drift autox
yeah i got mine all hooked up and its fairly acurate
bmarley5780
cool thanks, how much do u think they charge for one at the junk yard?
vududoc
for the sender? go to http://www.car-part.com and if you need help on the wiring i have pics and instructions
bmarley5780
can u send them? I had one but gave it away/.....didnt know i would work.....:( [email protected]
