Speed sensor check
leslie53
Car: 93 300zx 2+2
Hello,
Please advise, I have 93 300zx none turbo automatic. My speedometer stop working and my gears shift erratic (4000 RPM +-) various post mention speed sensor issue.
Well I removed the Speed Sensor set volt meter to AC, and rotated pinion. Book says approx. 0.5v, my readings are fluctuating wildly as I rotate the wheel. It is totally unreadable.
It went as high as 3.999 wildly. Please advise, is the speed sensor defective?
m tr4nch
Car: RS13, Z31, P11
are you sure the volt meter is supposed to be on AC? i would think it should be on DC. maybe try that and see what the reading is?
leslie53
Car: 93 300zx 2+2
Thank you for you reply,
The manual says AC voltage
