Speed sensor/accessing the sensor plug
ZacGolden
Car: 1993 300zx n/a
So i took out my speed sensor today and all thats left is to unplug it, problem is its running along the top of the transmission were I cant get my hand into. Has anyone ran into this problem, could I take the center console out to access it from the top?
ThisIsSparTTa
Car: 91 300ZX TT 2+0
Find a friend with smaller hands. People swap speed sensors, and I don't think its supposed to be terribly hard.
If you take out the exhaust, you can remove the heat shields if that helps. If you have a transmission jack, you could remove the driveshaft and then the rear transmission mount and let the transmission drop a little. I haven't done just the speed sensor though, and that all seems way too complicated.
ZacGolden
Car: 1993 300zx n/a
yeah i have pretty large hands. I am gonna to try to attack it from another angle. im gonna try to go in between the front tire since the ECU is right there. the maybe I can see the wire coming from it
