float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Thu Apr 08, 2004 12:44 pm
I assume this is for an analouge speedo? (has needles) If so, the problem is either in the speed sensor (doesn't sound like it) or in the actual cluster itself. The way to test it would be to pull the speed sensor out of the back of the transmission. If you are underneath there car there is a cylndrical device with 2 wires going to it at the back of the transmission. That is the speed sensor. The connection for it is up farther in the wiring loom somewhere, Unplug it and then remove it from the transmission. If you can jack the rear of the car up, it will help otherwise you will loose a bunch of transmission fluid. When you have it removed, attach a voltmeter to the plug, set it to VAC and then use a drill on high speed to turn it somehow. If you are getting stable voltage out of it at a stable speed, then it is fine. (Once again, I seriously doubt this is the problem) If it does check out alright, then it's probabally the gauge cluster and I have no idea how to check it other than replacing it with a known functional one and see if the problem goes away.
