twistedsymphony »
https://forums.nicoclub.com/twistedsymphony-u62853.html
Thu Jul 17, 2008 4:16 am
first thing you should do is check if your odometer/trip meter is working the signal goes from the VSS to the speedo then to the odo/trip
if the odo/trip ARE working then the problem is with the gauge itself, you can get a new cluster/speedo or use a company like DNA Speedometer to fix it.
if the odo/trip are NOT working then problem could be with the VSS... you can test the vss easy enough by using a multimeter and twirling it by hand, if you get a signal than it's good and the problem is with the gear in the transmission.
