spec-u-later »
https://forums.nicoclub.com/spec-u-later-u7110.html
Tue Apr 27, 2004 10:28 am
The s13 and s14 have different cut points. Both can be solved very easily and has been discussed many times. The s13 cut out is 110 ar at thats what my HUD said. The s14 is about 120. I am speaking for manuals on both. Autos do have a fuel cut it is just higher, like 135. On both cars all you do is cut one yellow wire with a grey stripe on your ecu and unplug your 4th and 5th gear rev limiter from your transmission. You are now only limited by redline. BTW the HUD only dislpays up to 125. I have gone 1000 rpm beyond that point and could have kept going with more road.
