Speed limiter
pignose
The other day we read about the speed limiter and how to get rid of it. so when the ecu is bolted on the car in stock position it is the left row eighth wire down the yellow wire with a green stripe on it right? We cut the wire in half .We went out to test it and the car only went up to 75 mph the cut the fuel off just like it used to do at 115. do you know what is wrong?
jab11185
Car: 1992 Nissan 240sx
did you un-plug the 5th gear tach sensor on the transmission?
XcreatureX
Car: 96 240sx SE
is there any other way to do this besides unpluging ****?
Seth
jab11185
yep
get ur ecu tuned
