evildky »
https://forums.nicoclub.com/evildky-u13100.html
Mon Nov 20, 2006 7:29 am
Welcome to NICO
you might try phrasing your questions a bit more disect, are you asking if there si a speed limiter on the Z31? I beleive the turbo Z31 has a speed limiter in the ECU of 145mph? (I'm sure AZ-Zbum will correct me here) and I believe the N/A's did nto have the speed limiter, they just lack the power and gearing to go any faster than that
most street cars run out of revs and gearing somewhere around that ballpark, unless you trying to set a record at bonniville or at the drag strip in which case you'd have other provisions, it shouldn't be a problem
