Speed governors suck hardcore! Need help finding ECU
"Racer X"
Car: rip 1991 240sx hatchback 140k
Since i would like to rev to 7100 rpm in every gear. . .i need to know where to find a cheap automatic KA ecu!
Also, would there be a difference between the 89-90 ka auto ecu's and the 91-94, since the older S13's were SOHC?
Oh, if you have other ways of SAFELY removing the governor/speed and rev limiter let me know.
I was looking at precision speed chips on ebay. . .i dont think they will solve the rev limitting problem but improve overall HP, i'm not sure how to verify this so i just messaged a few people who bought them on ebay with some questions, i'll make sure to post the results soon.
fatboy
Car: s13
i put a switch in series with my vss and ecu. its great
"Racer X"
fatboy wrote:i put a switch in series with my vss and ecu. its great
please explain what all of that is. . .
fatboy
Car: s13
you get a switch (any type) from like a radioshack or something. take off passenger kickpanel and find the ecu. find the vss wire (i cant remember exactly which one it was) and cut it. connect each end to the switch (dont matter which side) i drilled a little hole in my glovebox to put my switch in and tucked my wire so no one knows a thing. whenever i want, i can open my glovebox and flip the switch, the speedo wont work anymore but i can go as fast as i want. ive cruised at 140+ in a damn near stock sohc 240!
chrislis
Car: 1998 240sx sE!
im going to want to do this. what type of switch did you use?
SHIFTrl240
Car: 1990 SR20 Sil-80
2009 Yamaha RoadStar Warrior
2017 Alfa Romeo Giulia Ti AWD
cut gear sensor wires
problem solved
Megadeth
Jim Wolf it...
240DRFT
why do u want to rev to 7100 when redline is like 6800 and after a certain point your not gaining any more power
JimmyMethod
Car: 97' 240SX SE
Yeah, if anything, you'll be accelerating better if you shift. More power away from the redline.Besides, the redline is there for a reason. Your engine isn't built to go past 7k safely until you upgrade your internals.
dfw240_EE
Car: 1992 240SX
I thought on the S13 the speed governor was a lower RPM cut in 5th gear, so you just cut the 5th gear switch. Is that for manual ECU's only?
"Racer X"
All of your comments are great and generally valid, but the main question is where can i find an automatic KA ecu? I've looked for the past few days to no avail. . .
I want my spedometer to work. . .and i don't necessarily want to push my car to 7100 rpms but also dont want a cutoff switch making that decision for me.
574-240sx
Car: Nissans, Toyotas, Subaru
Try Junkyard, Ebay, or post a WTB add in the classifieds.
808DRFTR
Car: 89 240sx KA24DE Swap
91 240sx SR20DET Swap
02 Sentra SER Spec V
01 QX4 4x4 Lifted
01 I30
11 M56 Sport
Answer to your question, Get a Apex Rev/Speed Meter or get your ecu tuned
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
or drive liek 90% of the rest of us
Florida240sx
drifter_for_life06 wrote:or drive liek 90% of the rest of us
We are making up that 10% DOHC S13 ecu pin 32 cut the yeloow wire with green stripe...your problem will be solved. Teste don a 93 dohc and 91 dohc works great.
hek1620
Car: '89 240sx
how about for an'89 sohc?
"Racer X"
Florida240sx wrote:We are making up that 10% DOHC S13 ecu pin 32 cut the yeloow wire with green stripe...your problem will be solved. Teste don a 93 dohc and 91 dohc works great.
will my spedometer still work?
streetracer
Car: 240sx hatch
Yes the speedometer will still work I know this because i have done the wire cutting of the yellow/green wire and i have cut two more wires for the 5 and 4 rev limiter wires but the gas cut off catches up for some reason. unless i cut the wrong wire for the rev limiter.
